enable ripng
enable ripng
Description
Enables RIPng for the whole router.
Syntax Description
Default
Disabled.
Usage Guidelines
Although RIPng is useful in small networks, it has a number of limitations that can cause problems in large networks, including:
  • A limit of 15 hops between the source and destination networks.
  • A large amount of bandwidth taken up by periodic broadcasts of the entire routing table.
  • Slow convergence.
  • Routing decisions based on hop count; no concept of link costs or delay.
  • Flat networks; no concept of areas or boundaries.
For larger networks, consider OSPFv3 as an alternative IGP.
The following command enables RIPng for the whole router:
enable ripng
Platform Availability
This command is available on platforms with an Edge, Advanced Edge, or Core license. For licensing information, see the Switch Engine v33.1.1 Licensing Guide document.
